OBD-II WiFi adapters and ipad or mobile device
Has anyone had any experience with using say an iPad to monitor their XK ?
Is an XKR 2005 compatible with OBD-II WiFi adapters ?
I was just looking at this and wouldn't mind trying to do it and have the ipad in the car .
rgds Esh
rgds Esh
It should work fine, but you will be limited to engine & transmission codes and data, as with most generic OBD-II Scanners. There will also not be support for anything that is not sensed in the vehicle, such as oil pressure (there is just a low pressure switch). Some systems allow adding aftermarket sensors however.
Thanks, I'm just trying to find out now what parameters are measured and if the codes are standard so I can find a wifi / Bluetooth OBD adaptor that will work well.
Anyone have any info on this or has actually done it I would really appreciate it.
rgds Esh
rgds Esh
FS[NorthEast]: 2008 XJ Super V8 - Black on Cream
sg997tt
Oct 9, 2015 10:57 PM
