octupus hose left side norma replacement 2003 XKR
Old Apr 4, 2023 | 10:04 AM
adikesdw's Avatar
Default octupus hose left side norma replacement 2003 XKR
I am trying to find information on removing the left side norma connector and replacing the plastic "T" with a metal "T" eliminating the norma connector. I have used the pipe/hose + clamps on the right side to remove the norma connector on that side. My local home depot has PEX brass reducing "T"'s in 3/4"X3/4"X1/2" and 1"X1"x1/2". I saw one reference on the forum where a member used a T reducer purchase at Lowes. Has anyone had long term success using this type of replacement? Any hints or suggestions?
Thanks,
Old Apr 4, 2023 | 11:05 AM
Jag#4's Avatar
Not sure if we are talking about the same "T", but maybe this thread will help. I was unable to find a suitable size in the plumbing department so had one made up.
https://www.jaguarforums.com/forum/x...s-hose-145013/
Old Apr 4, 2023 | 03:28 PM
adikesdw's Avatar
That is the perfect reference, thank you. I can't imagine finding someone to fabricate your part for me but a few questions. Do you happen to have the specs for the "T" that was made? The PEX "T" that I purchased from Home Depot labeled 1" X 1" X 1/2 " has the following dimensions: OD of horizontal arms is 21.6mm; OD of vertical is 11.8mm ; length of horizontal total is 61mm each arm is 21mm. So the horizontal OD is pretty close to 7/8". I hope these dimensions will be close enough to yours to work.
Thanks again,
Old Apr 4, 2023 | 06:40 PM
Jag#4's Avatar
I doubt I still have them (car was sold some years ago) but I will look thru my old notes. I will answer back here if I find it. I have added pictures of what I think was the original part that connected to all the maze of Jag hoses and connectors in case that helps. The Ford part number on the side is XW93 18A568-B. My simple T solution eliminated all of that for use with standard hose clamps.
Old Apr 4, 2023 | 07:30 PM
xalty's Avatar
if i remember right it's been a while since i did these..cut the norma off then get a 3/4 x 3/4 bridge some hose and another 3/4 x 3/4 with a 3/8 tee piece on it from autozone
Ophitoxaemia
Oct 11, 2024 06:38 AM
Jon89
Jan 3, 2021 04:23 PM
britannia
Jul 30, 2019 09:02 AM
srpope80
Jan 26, 2012 04:02 PM
SilverXJ
Jun 1, 2010 12:06 PM
