Oil Cooler Hose To Engine Block Retension Bolt Dimensions
Old Apr 4, 2025 | 06:08 AM
JACKP's Avatar
Default Oil Cooler Hose To Engine Block Retension Bolt Dimensions
Does anyone know the Diameter, thread pitch and length of the bolt that fastens the oil cooler hoses to the engine block on a 2005 XK8.
Jack
Old Apr 4, 2025 | 06:41 AM
Jon89's Avatar
I do not know the bolt specs, but I am wondering if you are still running your custom-made U-shaped metal tube connector as a replacement for your factory oil cooler lines....
Old Apr 4, 2025 | 01:48 PM
JACKP's Avatar
Yes Jon89 I am but plan on putting an oil cooler back on it. I hope to use the Setrab 50-613-7612 6 Series ProLine cooler if I can squeeze in the extra height.
I determined last summer that the oil cooler would be very beneficial stopped in traffic, and pulling hard while going slowly up the mountain (like behind a loaded dump truck)
I made my fittings that go into the front of the engine block before I knew that they are available from swollows.. Mine will require a longer bolt and if I had the specs. on bolt I could have it on hand.
Jack
zray
Dec 8, 2023 07:20 AM
Robbo D
Jun 8, 2023 12:25 PM
bullittandy
Dec 5, 2022 01:42 PM
Atlastajag1
Nov 10, 2016 03:18 PM
Bhpbug
May 23, 2015 07:39 AM
