Oil leak - anyone used dye ?
Old Dec 17, 2014 | 03:30 PM
franksm's Avatar
Default Oil leak - anyone used dye ?
Hi lads
Finally got around to changing out the two O-rings for the oil cooler lines on my 4.0. But a moment of aaaargh tonight, the oil leak is still there. I was pretty sure the mess was coming from the figure-8 oil-cooler fittings, so it must be something else (unless perhaps I have torn the new O-rings on fitting).
So, question, has anyone made use of a dye-based leak detection kit ? I plan to hose off the front of the engine again, put some dye in, run the engine for 10 mins and go searching. I hope the dye makes the task easier. I believe it comes with a little torch type thing
Old Dec 19, 2014 | 09:32 PM
aode06's Avatar
I have.
I always use the uv glasses ,uv dye,and uv light.
Then I ONLY LOOK AT NIGHT
Boeingtravel95
Sep 14, 2015 05:01 PM
jaggermang
Sep 8, 2015 07:07 PM
OkieTim
Sep 8, 2015 04:48 PM
Dymaxxion
Sep 4, 2015 02:40 PM
OkieTim
Sep 2, 2015 12:48 PM
