oil pressure/clock/voltage meter backlight replacement?
Old Nov 18, 2019 | 03:52 PM
gumby's Avatar
Default oil pressure/clock/voltage meter backlight replacement?
I have viewed the videos on replacing main dashboard back lighting for early-mid 2000's XK8s (Rev Jim's is very good) but I cannot find any resources on removing the center dash wood fascia to replace burned out back lights for the center gauges - the oil pressure gauge, clock and voltage meter. Does anyone have instructions or know of a video that explains the process? I am working with a 2005 XK8.
Thanks!
Old Nov 18, 2019 | 07:04 PM
avern1's Avatar
The wood pries straight out. Pry gently and work it towards you evenly. The mounted tabs are straight and just insert into the holders. Once that is done you have access to the mounts.
Old Nov 18, 2019 | 07:46 PM
DavidYau's Avatar
Default Try To The Garage Youtube series
John has a very good XK8 Youtube series. One episode covered these Centre gauges. Link below.
prettygirl69
E type ( XK-E )
Jul 15, 2015 05:35 PM
RaceDiagnostics
Feb 22, 2015 09:54 AM
amcdonal86
Mar 1, 2012 10:26 PM
2000blackxkr
Jan 29, 2010 10:54 AM
