overheating
Old Aug 27, 2008 | 03:22 PM
GordoCatCar's Avatar
Default RE: overheating
Check your thermostat.
Old Aug 27, 2008 | 07:19 PM
jag_genius's Avatar
check thermostat as gordo said .. and if the car is actually spitting up coolant thru the bottle.. then i wud definitly check the water pump.. pull it of and see if it has any blades left.. if not then thats the problem.. also check if fans are on high speed when over heating
Old Aug 27, 2008 | 10:30 PM
If you go that far, then replace the plastic t-stat housing with an aftermarket metal one. Cost about $90.
mikiep
Dec 20, 2019 07:37 PM
vwbusbits
Oct 13, 2015 03:43 AM
workworkwork
Oct 1, 2015 01:44 AM
bydand
Sep 28, 2015 09:47 AM
bydand
Sep 27, 2015 12:00 PM
