P0121
Old Jul 15, 2012 | 04:39 PM
RJag's Avatar
Default P0121
Hi Folks. I do not intend this info to be an easy one size answer for this code re the trottle body/throttle pedal but I thought I'd pass on what appears to have been a solution for mine, 2000 XK8.
I'd get it occassionally and I tinkered with the linkage then with cleaning the contacts in the plugs and it would be fine for a while then pop up again, usually after a good run then repeated movements in traffic. It occurred to me that the spring assembly was not always returning correctly. Why, I couldn't see but finally I sprayed lubricating oil liberally on the pedal cable and around the spring. I worked it in manually and I haven't had a code in a month now. I also returned the cable to a very tight condition rather than a bit loose by watching to ensure that fully off still rapped the butterfly back against the stops.
Hope that helps someone.
Old Jul 15, 2012 | 05:35 PM
mick99's Avatar
Exact same problem as You. Only at very slow speed and very intermitten(maybe every 100 miles or so) Same code p0121. TB was cleaned last year and I don't have mismatched plugs. Thinking about sending TB in for rebuild. Let us know if the lubrication was the solution. I have a feeling it's gonna come back, but I hope not! Good Luck.......mick99
Old Jul 15, 2012 | 07:14 PM
hdsg's Avatar
Default p0121 my fix
Hi all:
Had this code and cleaned and made sure tb connectors were tight. No joy on that as it returned. A fellow member suggested cleaning the ecm connectors and check a ground strap under the ecm unit that was sure enough loose. Once I cleaned and tightened it has never returned. This was last year. Also if you have a battery tender it may be a good idea to charge up your battery as its been mentioned that a weak battery can cause these issues. My car is a 99 xk8 convert and a left hand drive. The ecm and ground strap are under the hood by the windshield on the passenger side under the black lid. And my ground strap i could easily turn it by hand. Been almost a year now and its never came back ( famous last words !!!! )
Howard
Old Jul 18, 2012 | 03:45 PM
RJag's Avatar
Default update on P0121
Well, so far so good. Running at varied temps, both short and log hauls.
I'm also parked on a very dirty construction site for most of the days so that can't be helping.
PaulB
Jul 12, 2016 05:27 PM
nonfinito
Nov 20, 2015 09:57 AM
Sq-STR
Aug 27, 2015 07:27 AM
Vbolden1
Aug 7, 2015 09:09 AM
larryjk
Nov 11, 2014 04:14 PM
