P0175, P0172, P0301/4, CEL, Restricted performance experienc
Old Jun 16, 2021 | 11:36 AM
David Dougherty's Avatar
Default P0175, P0172, P0301/4, CEL, Restricted performance experienc
Out to give the car a little work out and the CEL comes on and I get a "restricted performance" message.
Ok, two codes P0175 & P0172 indicate engine running rich all cylinders, Clear codes clear MAF connectors drive car.
Again CEL light comes on codes P0301 to P0304 indicating misfires on all cylinders, left bank.
Ok, time for a little clean up. New air filter, STP fuel inkjector cleaner in tank. Purchase CRC Throttle Body and MAF cleaner. Apply all to car.
Check car for leaks and loose connections, nada.
One note here and the reason for this posting. When cleaning the throttle body I left it on the car. To open the butterfly valve you put the ignition into run, don't start car but depress the gas pedal and the valve opens! No need to force it open.
Once all cleaned car started right up and runs great, no codes or lights. One really nice feature on these cars is a little maintenace can really make a big difference.
Old Jun 16, 2021 | 02:21 PM
Jon89's Avatar
Well done. The only suggestion I have is to use a 20-ounce bottle of Chevron Techron instead of STP next time. Techron is a great product. All of our vehicles get a 20-ounce bottle down the fuel filler hatch at every oil & filter change....
Old Jun 16, 2021 | 07:16 PM
RJ237's Avatar
Those codes could also be related to a low battery. Getting it
load tested at a parts store would not be a bad idea.
grahamspeller
Apr 27, 2023 05:05 PM
Map53
Jan 23, 2022 05:47 PM
mpodurgiel
May 30, 2017 02:00 PM
WaterDragon
Mar 13, 2014 12:43 PM
Miami XKR
Aug 24, 2010 11:28 PM
