P0193
Old Mar 25, 2021 | 12:08 PM
wrischan's Avatar
Default P0193
Suggestion on why error code P0193,
should I just change sensor?
When I clear code car runs ok. When code shows up it stumbles a bit When cruising. Still accelerates ok.
Old Mar 25, 2021 | 01:07 PM
fmertz's Avatar
I believe this happens when the fuel pressure is suddenly required to drop, like when you close the throttle when cruising. When that happens, there is a valve at the pump that is supposed to pop/release the pressure. If that does not happen, the pressure at the rail rises (as compared to manifold pressure) and the sensor maxes out. I would start with your favorite injector cleaner (Techron III is well liked here) to see if that frees that pop valve. Otherwise, the fuel pump has to be replaced ($$$). This is a tricky/sometimes error, which complicates the diagnostics. AFAIK, there are no aftermarket valve or pump, the whole assembly has to be sourced as a Jaguar part.
Best of luck, keep us posted.
Old Mar 25, 2021 | 07:15 PM
cjd777's Avatar
wrischan, I can not find out what year of car you have and XK or R type.
Checking the fuel rail pressure may tell us something.
No location, so don't know if a member is near. You have been with us a long time, thanks for that.
nickdabs
Feb 21, 2020 05:59 AM
cforne7
Oct 8, 2019 09:06 PM
jelu02
Jun 8, 2018 08:09 AM
mick99
Feb 1, 2016 10:51 AM
