P0442 code will not clear
Old Nov 16, 2023 | 03:01 PM
tonyberry's Avatar
Default P0442 code will not clear
I have a check engine light with the code P0442 small leak in EVAP system. I've installed a new canister close valve, vapor pipe assembly and canister purge valve. The P0442 code will not clear with my scan tool. I hit the erase function and the code comes right back without the engine going through a start cycle. The check engine light has gone out once while driving and come back on in a few minutes. Anyone have any ideas of what the root cause could be? Electrical connection? Thanks, Tony
Old Nov 16, 2023 | 03:07 PM
tonyberry's Avatar
I forgot to identify the car with the problem. It's a 2000 Jaguar XK8 with 30,700 miles. Thanks
Old Nov 17, 2023 | 07:34 AM
NorXKR's Avatar
I had the same fault code on my 2000 XKR. But you should be able to clear the code, and it should not come back on the first trip. Neither should it come back if you have a full tank of gas.
Have you tried a different scan tool?
On my car it was the o-rings on the canister pipes that needed replacement.
Old Nov 17, 2023 | 09:53 AM
tonyberry's Avatar
Thanks for the response. I'll try another scan tool and o-rings.
Markel
Jun 2, 2021 07:57 AM
mikebaker3
Jul 21, 2019 12:21 AM
rogerpaulsen
Apr 22, 2019 08:19 PM
rainbowboy
May 29, 2014 10:20 PM
twoblackjags
Oct 9, 2011 06:38 PM
