passenger occupantcy sensor
Old Jan 2, 2022 | 05:01 AM
jeffspain's Avatar
Default passenger occupantcy sensor
I had the fault code B2291 and flashing amber warning light (2-7 flashes). The local Jag specialist said it was the passenger occupancy sensor, which they sourced and replaced. However this has not cured the problem. I still have the warning light and I'm told the diagnostic machine now says 'low threashold'. They think it must be a wiring problem. Has anyone else had this and was there a solution?
The mechanic that fitted the sensor says he thinks it could reset itself after a while, but no luck yet.
Thanks for any replies.
Jeff
Old Jan 2, 2022 | 11:49 AM
STLTHMSTA's Avatar
Will the code reader reset it like many other trouble codes?? Worth a try. TM
Old Jan 2, 2022 | 03:16 PM
astromorg's Avatar
As STLTHMSTA suggested, clearing the code and seeing if it comes back would be a good start point. Let's hope!
Unfortunately, B2291 and Flash code 17 are applicable to quite a number of potential faults associated with the Passenger Occupancy System and to differentiate between them requires a good Jaguar enabled scanner that gives the Bxxxx codes in the form Bxxxx(xx). You'll see what I mean if you check out FC 17 in the attached document. It appears in some form on most pages! I wonder if your mechanic had the gear to enable him to pursue the right possibility?
The good news is that a lot of possible causes are listed against the various versions of FC 17 faults
File Type: pdf
Jagfan4468
Sep 3, 2021 11:50 AM
gsubrec
Oct 2, 2020 04:08 PM
JagJoe80
Dec 16, 2018 06:49 AM
talulah
Oct 2, 2014 09:06 AM
carlorner
Aug 29, 2011 12:17 PM
