Coolant warning Light - RESOLVED
Old Dec 3, 2018 | 07:17 AM
JagJoe80's Avatar
Default Coolant warning Light - RESOLVED
Hi
Every time I turn the engine on my Coolant red warning light comes on immediately and does not go out.
I have checked the level and all good. Cleaned out the resevoir and sensor seems ok. However the light stays on, would appreciate your advice.
Cheers Joseph
XK8 - 1998 - Blue - 130,000miles
Last edited by GGG; Dec 18, 2018 at 05:45 AM. Reason: Add "RESOLVED" to thread title
Old Dec 3, 2018 | 08:31 AM
JimmyL's Avatar
I had that problem, or a similar one. The red light would come on and the temp gauge needle never moved from the bottom. I read the code and it was a P1646 (I think), about the
ECT circuit open, or something like that. Anyway, I reset the code, the light went out and the gauge started working again. No problem since. I'm not sure what happened, but this
happened just after I had put the ODBII reader on it to check something else.
Old Dec 3, 2018 | 08:42 AM
JagV8's Avatar
P1646 would be a failed O2 sensor.
On the warning light it's likely a bad sensor, bad connection, chafed wiring...
Old Dec 3, 2018 | 09:23 AM
motorcarman's Avatar
The float in the reservoir can get stuck or sink. The sensor can fall out the bottom and trigger the warning.
bob
Old Dec 4, 2018 | 09:32 AM
JimmyL's Avatar
Talking
No, it was a P0116.
Old Dec 16, 2018 | 06:49 AM
JagJoe80's Avatar
Thank you everyone for your input, much appreciated. At the end of the day I found that it was a poor sensor connection at the bottom of the overflow resevoir. Such a simple fix. All OK now.
Thanks again
Cheers a Happy Chappy now.
slmskrs
Nov 12, 2013 02:08 AM
JLee
Oct 6, 2012 09:46 AM
Wolfy
Nov 16, 2010 07:42 PM
kennith13
Oct 19, 2010 12:25 PM
martinese
Sep 10, 2008 08:44 PM
