Passenger window does not work
Old Jun 23, 2016 | 09:13 PM
Mogmichael's Avatar
Default Passenger window does not work
Okay, have a number of issues with the passenger door solved but the window does not work. Stick about 3/4" down. Window switches AR working because I can hear a relay (or something) click whenever one is operated up or down. Have checked the fuse for the door module. Someone suggested the actual main door harness connection. But where is it and how does one pull the connection apart. I will try electrical contact cleaner if I can break open the harness multi-pin connection. Advice?
Old Jun 24, 2016 | 07:22 AM
BobRoy's Avatar
The connector is on the outside of the door between the door and the chassis on the hinge side of the door. The connector is round and you remove it by first turning it counter clockwise, this is locking connector, then pull it out. Mine made the clicking sound like you mentioned when I used the wnow swhich and the window was not working.To test the ground wire I found the ground wire on the harness going into the module , then I used a jump wire from there to the chassis and the window and mirror worked. That told me there was a bad ground between the door and chassis. After looking closer I found that the ground pin on the connector was corroded. Cleaned it up and no more problems. I don't know if this is your problem but it is worth a try.
Old Jun 26, 2016 | 04:01 PM
Mogmichael's Avatar
Default Passenger window issue SOLVED!
BobRoy,
Thanks for your info on the door connector at the jamb. I took it apart and cleaned it but did not get a change in the window operation. Still dead! Was hoping to solve the issue without tearing into the door (looked for anything obvious externally first) but finally decided and had the time to take the door apart on Saturday. Panel off and speaker out. Reached in and probed around and immediately found the problem. SEE PHOTO!!!
Another simple fix!
Attached Thumbnails Passenger window does not work-right-side-window-motor-connector.jpg
teroks
Oct 2, 2022 04:38 PM
xjrjag
Apr 14, 2016 11:57 AM
xjsman89
Apr 13, 2016 12:52 AM
Andi Baker
Apr 9, 2016 05:51 AM
Jagjagplayingup
Mar 29, 2016 03:11 AM
