PCV valve in 4.0L V8 engine?
Old May 16, 2016 | 12:57 PM
Pristine97XK8Convertible's Avatar
Default PCV valve in 4.0L V8 engine?
Gents,
Please pardon my stupid question.
Is there a PCV (Positive Crankcase Ventilation) Valve in the 4.0L Jaguar V8 engine, because I can't find one? If there is one, where is it located/connected?
Otherwise, by what means is the Jag 4.0L V8 engine's crankcase ventilated?
Old May 16, 2016 | 02:13 PM
dsnyder586's Avatar
Yes. It is through the "part load breather" and Full load breather" They are on both cam covers, full load is no the air cleaner side, and the part load on the other. Easily spotted by their "accordion" hose look.
Old May 16, 2016 | 07:34 PM
cyber3d's Avatar
Here is a TSB on cleaning the PCV.
https://www.jaguarforums.com/forum/a...-600-03am3.pdf
Old Oct 4, 2016 | 08:03 PM
MikeofBonsall's Avatar
Originally Posted by cyber3d
Thats only pre 2003. Confused me for ever till I found the PCV valve on later models
Old Oct 5, 2016 | 01:27 PM
Dale Dunn's Avatar
Are the part load breathers replaceable? Mine is broken in valve cover and I can't find replacement except by buying complete used valve cover
Old Oct 5, 2016 | 01:33 PM
How do I know if my PCV valve needs replacing. I found one for $51 but don't want to waste money if I don't need.
Old Oct 5, 2016 | 02:19 PM
RJ237's Avatar
Is it causing a code? If not it's okay.
Cadillac
Diesel variants - All models
16
Nov 19, 2016 02:35 PM
pagodino
Aug 31, 2014 06:29 PM
Soccer6planer
Jul 7, 2012 09:17 PM
Njxfsc
Jun 14, 2012 02:17 PM
