Plate lights and high mount brake lights out
Old Aug 12, 2020 | 08:38 AM
Barry_Tucker's Avatar
Default Plate lights and high mount brake lights out
Last evening I noticed that my rear number plate lights and boot lid mounted brake lights have stopped working. I tested the number plate bulbs and they are ok. Since both stopped working at once I assume that there is a failure in the wiring harness to the boot lid. I will track it down but , given the wealth of experience here, I am looking fro some common locations ( other than the obvious place where the wires flex going from the body to the boot lid )
Old Aug 12, 2020 | 10:02 AM
Jon89's Avatar
Over the years most owners who experience this problem have indeed found the culprit to be in the area where the trunk wires flex. I would certainly start there....
Old Aug 14, 2020 | 08:36 AM
Fixed: ground wire broken where the harness flexes. No doubt , it will eventually fail again, but not a huge problem
Old Aug 14, 2020 | 09:10 PM
jacobmstein's Avatar
Yeah I had the same issue recently, spliced in the harness from a 30,000 mile parts car, but only after getting pulled over 3 or 4 times.
fuzzysquid
May 17, 2019 10:20 AM
Leet8845
Nov 21, 2017 04:53 PM
adenshillito
Apr 19, 2016 05:46 AM
martek
Oct 1, 2014 11:50 PM
rotor jockey
Sep 17, 2010 05:52 AM
