please help 02 xkr wont start
Old Apr 9, 2013 | 03:21 PM
joyroadboy's Avatar
Default please help 02 xkr wont start
i stored my xkr for the winter and battery died in that time now it will turn over but no start dash says no acs and no trac available please help today is my bday and want to drive this weekend do i need the factory radio back in it or do i need to reset ecm
Old Apr 9, 2013 | 04:07 PM
WhiteXKR's Avatar
Try disconnecting your battery for a minute then reconnect it. If that does not solve the problem, measure the voltage on the battery...if it is under 12.4 volts your battery is either not fully charged or needs to be replaced.
Starting the car with a dead battery from jumper cables may not be successful. The battery needs to be charged.
Old Apr 9, 2013 | 04:23 PM
IanP's Avatar
If the above suggestions all pan out check the fuel pumps are by listening for them from the boot. And fuel. Rail pressure.
IanP
Old Apr 9, 2013 | 04:31 PM
joyroadboy's Avatar
i just got battery back from being charged will check suggestions and follow up but never had this problem always could boost and start right up could it be because of aftermarket radio
Old Apr 9, 2013 | 04:35 PM
WhiteXKR's Avatar
Whether a jump will work or not depends a lot on the condition of the battery, the condition of the jumper cables and the length and wire gauge of the jumper cables.
Old Apr 9, 2013 | 05:17 PM
joyroadboy's Avatar
ok so i put battery in still no start dont hear pump in trunk and no pressure at fuel rail should i check for fuse or relay and if so where is it located no manual with car purchase any other ideas
Old Apr 9, 2013 | 05:25 PM
You can download all the manuals for your vehicle as PDF's from here:
https://www.jaguarforums.com/forum/x...-2003-a-67827/
Fuse and relay details are in the Vehicle Care Handbook.
Old Apr 9, 2013 | 06:24 PM
RJ237's Avatar
Be aware that there have been numerous reports of fuel pumps failing after winter storage.
Old Apr 9, 2013 | 08:07 PM
Gus's Avatar
Gus
This link should help it also has information on the fuel pump fuses.
Old Apr 10, 2013 | 06:01 AM
joyroadboy's Avatar
ok i hear the relay coming on then turning off so my luck its fuel pump. so i have heard there are 2 pumps on the xkr is this true? im going to order pump today and if there is 2 do i replace both and are they both in same place
Old Apr 10, 2013 | 06:53 AM
WhiteXKR's Avatar
Yes replace them both. It is penny wise and pound foolish not to.
Also check the wires in the tank for continuity before putting it all back together. It is common for them, or the black electrical noise filter (called the 'lead link') attached to the wires to fry when the pump fails.
You might also want to try removing the main fuel pump relay and try starting the car about 5 or 6 times. If the secondary fuel pump is still working, it will take over and actually allow the car to run in a reduced power mode. If this does not work, then your secondary fuel pump is also bad.
Both pumps are in the tank.
Old Apr 10, 2013 | 08:40 AM
joyroadboy's Avatar
where can I purchase the pumps from? I called autozone and advance auto parts but they only show 1 pump is both the pumps the same?
Old Apr 10, 2013 | 08:45 AM
Gus's Avatar
Gus
I use Jagbits.com
Old Apr 10, 2013 | 08:49 AM
WhiteXKR's Avatar
The XKR (up to 2002) has two identical pumps.
Old Apr 10, 2013 | 09:04 AM
Mountaincat's Avatar
Did you check the voltage on the battery? I would rule out other possible causes before replacing the fuel pumps. In my experience a relay may close in on a lower voltage than it takes to drive electric motors (fuel pump). I would also check voltage across the fuel pump relay.
Old Apr 10, 2013 | 02:36 PM
IanP's Avatar
We have another guy in the UK with the same problem.
Bloody pumps.
WhiteXKR is spot on as are all the above posts.
Been there and done it..........
IanP
Old Apr 11, 2013 | 07:00 AM
joyroadboy's Avatar
ok so what I have done so far, got battery checked and charged, battery is good no warning lights on information like I had before as to the acs and trac unavailable, crank but no start, i have spark, found out by my assistant turning over before I said bump it and got a good tingle up the arm so got spark, can feel relay for pumps come on and go off, so leads me to believe the pumps are bad. now a question I have is if there are 2 pumps in the tank why doesn't at least 1 pump work to make the car at least run? even if just barely. well I will be checking the rest of the fuses as soon as this rain ends not really fond of water and electrical things. thanks everybody for your input and suggestions it has gotten me farther than I would have ever gotten by myself, especially since I cant get a repair manual from the local auto shop
Old Apr 11, 2013 | 07:05 AM
WhiteXKR's Avatar
Please go back and reread post #11. I explain how to get the car to run on the secondary pump, assuming the secondary pump is good.
If this does not work your secondary pump is also bad. Many people never notice when the secondary pump fails. During normal operation the secondary pump only runs during high throttle (plus it primes when the car is started).
Old Apr 14, 2013 | 10:53 AM
joyroadboy's Avatar
ok so I got a chance to go out and check all the suggestions with fuel pump fuses relays etc and came back with all fuses good relays good used jumper to jump relay and I have power to the tank. I also removed the primary relay to see if it would start still no luck so I guess its off to get the pumps today and start the job. I looked up a video of fuel pump replace and I think I should be able to achieve the job. is there anything I should replace while im in the tank that could be a problem later on?
Old Apr 14, 2013 | 11:35 AM
WhiteXKR's Avatar
Make sure you check the electrical continuity of the wires in the tank. Sometimes they visibly burn up, and sometime the black 1x1" device on the wires (which is an electrical noise filter) burns up internally when the pump fails.
Also consider replacing the fuel level sender whle you are in there. They are pretty fragile.
