power connection up front
Old May 1, 2012 | 05:27 AM
oldjaglover's Avatar
Default power connection up front
Which is the correct + post up under the hood for using a trickle charger? I believe it's in the right side box behind the strut, but I don't know which exact one.
Old May 1, 2012 | 06:22 AM
test point's Avatar
There is a picture in the FAQ sticky above. There are power connections on both sides.
Old May 1, 2012 | 06:55 AM
simkins's Avatar
It should be covered by a rubber cap
Old May 3, 2012 | 05:17 AM
Ah, yes. I looked closely at the schematic pics and the best path back to the battery seems like it would be on the right side of the car (same side as battery and hi load fuse block), but the drawing suggests the opposite. Of course, that drawing doesn't quite show the junction that splits the + cables off to each side under the hood.
I guess the ideal post would be the one that hits the starter. Anyway, I'm just giving it a 1.5 amp trickle charge to keep the battery strong. I hooked up to the left side because it is where I can easily look out to the car and see the lights on the charger.
Forcedair1
Sep 8, 2025 01:57 PM
mbergen
Oct 23, 2019 10:26 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
d a
Sep 3, 2015 02:34 AM
