Power steering reservoir
Old Mar 12, 2015 | 10:51 AM
mclarenf1fan's Avatar
Default Power steering reservoir
Does anybody know how to swap out or clean the filter / back flush it on the p/ s reservoir? I have to change the rack and pinion on my '97 XK8 Convertible and don't want to replace reservoir if I can avoid it. Thx.
Old Mar 16, 2015 | 05:32 AM
203 Views but no Replies.
The only times I've known anyone to replace a Reservoir is to fix a leak and, if you search the forum, this appears to be extremely rare.
Is the flow restricted owing to a blocked filter?
Old Mar 18, 2015 | 11:57 AM
Default Power Steering Reservoir
According to JTIS you should change the reservoir whenever you change the rack. Apparently the filter should be replaced and as it is integral with the reservoir . I just don't want to spend the money on a new reservoir with its built- in filter if I can avoid it . There does not seem to be any restriction in the flow so I am assuming it is not too bad, i figure it is a good opportunity to flush the entire system while I've got it . It should be possible to back flush that filter. I need to find a way to do it.
Mac Allan
Oct 27, 2015 04:49 AM
bigblackcat3
XJ40 ( XJ81 )
Sep 14, 2015 04:03 PM
1964Daimler
Sep 9, 2015 11:28 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
