First, my apologies, I have been lurking around over time but just not positive I have the info I need, and get more confused every time I search.
OK Faith is a 99 XK8 vin SAJGX2045XC032381, 42K miles now. I believe she has the original tensioners, original water pump, original t-stat housing. I am fixing to order tensioners and gaskets, water pump, t-stat and housing, belts, belt tensioner (seems noisy) air cleaner, plugs.
I have neighbors who are great independent mechanics that will do the work for me with my parts.
I'm paranoid about getting the correct parts.
This is an AJ27, correct? The Ford tensioners and bolts work for me? It seems from all my reading the 99 was in various states of transition thru it's production so I'm unsure.
Aside from replacing proactively these weak links and cleaning throttle body and MAF, any other recommended items while she's down for a week?
PLEASE CREATE LINE BREAKS!
JimC64
close
- Join DateNov 2006
- LocationGlasgow, Scotland UK
Liked:9,029 Times in 4,120 Posts
Hi there, sounds like you're really on top of things?
The XK8 DIY tech / gurus will no doubt be along to help soon.
I wish you the best of luck
philhef
close
- Join DateFeb 2011
- LocationNorth Carolina
Liked:544 Times in 338 Posts
I had coolant hose issues. Check the expansion tank as they tend to leak underneath, check the octopus hose as well we found leaks there. Minor leaks but caused coolant smells.
Btw, I gotta get me one of those Mexican leapers!! Love that pic!!
WhiteXKR
close
- Join DateApr 2010
- LocationArlington VA USA
Liked:3,019 Times in 2,141 Posts
Yes and yes. Originally Posted by cheaperts
ArtyH
close
- Join DateAug 2013
- LocationNorth Northumberland England
Liked:77 Times in 58 Posts
interesting thread, I tried the vin identifier but got nothing, is this just for U.S vehicles?
My VIN SAJJGAED3AH042585 does not come back with any results. Anyone know of why this is or how I can check my car using a similar application?
Kind regards,
ArtyH
Kind regards,
ArtyH
Well finally got it all ordered, I've decided to park her till it's all done, making a lot of noise at the front of the engine, not a rattle or chain noise but bad whine and growl, seems belt/roller to me, hopefully not related to the alternator or compressor, but definitely front of engine between 2500-3500 big whine going on, so she's in time out.
I was really surprised on how cheap I got all the parts! Tensioners and bolts from Sunroad ford online was 122.00 before freight
From Rockauto ordered Felpro gasket set, water pump, thermostat, t-stat housing, brakes all 4 wheels, belt, belt idler, plugs, air filter all for 277.00
400 bucks plus some labor, and probably swap printing them a few shirts and she will be all sorted!
Now, gotta find a paint-less dent guy to fix the quarter panel that got attacked by a shopping cart............
