Problem with passenger window
Old May 27, 2022 | 04:07 AM
Defender99uk's Avatar
Default Problem with passenger window
My passenger side window doesn’t want to go back up when I shut the door, but when I open the door it drops that little bit more, I’ve reset the maximum height and maximum drop a couple of times but doesn’t make any difference, any ideas please
Old May 27, 2022 | 04:26 AM
Pistnbroke's Avatar
sure you heard the click at top and bottom?
Old May 27, 2022 | 06:07 AM
Jon89's Avatar
If you have tried the window reset procedure multiple times with no success, you may be dealing with a dying battery....
Old May 27, 2022 | 01:28 PM
Yes I have heard the click every time, and no it’s a brand new battery only fitted for two weeks
Old May 27, 2022 | 01:38 PM
As this affects only ONE front window and you can hear the 'click' of the limit switches during the travel reset procedure, the next possible culprit is the door module.
Old May 30, 2022 | 02:12 AM
I’ve read somewhere that it could also be down to one of the micro switches on the lock mechanism but which one would it be
Old May 30, 2022 | 02:16 AM
Pistnbroke's Avatar
Personally I dont think its a microswitch ...there are 5 in my doorlock !!!
Sadly you cannot swop the controllers as the drivers and passengers are different.
Old Jun 6, 2022 | 10:59 AM
Update, just found some time to check out this problem after reading all the advice, I thought why don’t I try another hard reset before taking off the door card and having a root around inside the door. Yes that has cured the problem, passenger window now works as it should again, thanks to everyone for your help
dwilk
Apr 25, 2022 12:29 AM
BlueSmudge
Aug 14, 2021 11:17 AM
GBCat
Aug 1, 2021 03:11 PM
TTG
Nov 8, 2018 04:47 PM
Woodrun
Sep 18, 2018 10:51 AM
