Proper Compression Readings...
Old Jun 20, 2012 | 01:08 AM
WillyWheels's Avatar
Default Proper Compression Readings...
Hey guys,
I am acquiring a 1998 XK8 needing engine replacement.
I'd like to have a compression test done on any engine I purchase to swap in, but what are the correct or acceptable compression readings for the 4.0?
BTW, I'm not very mechanically inclined, what is the process or procedure for taking engine compression readings from an engine removed from a vehicle?? How about when it's in??
Thanks!
Old Jun 22, 2012 | 07:53 PM
jagmon's Avatar
You can take a vaccum test and get a good test plus check the valves in 5 minutes.
Old Jun 22, 2012 | 08:40 PM
CleverName's Avatar
Sadly, I think your in the wrong forum. This is for '07 and newer, so hard data is not anything I can offer.
I recommend you read this artical and do a leak-down test rather than a compression test.
How to do Cylinder Leak Down Testing- Car Craft Magazine
BOL
Vince
Old Jun 23, 2012 | 07:09 AM
dennisw's Avatar
BOL
Vince
-1
PhilXJ6
Jan 3, 2016 08:55 PM
pnwrs2000
Nov 17, 2015 04:04 AM
redxk8
Oct 4, 2015 08:28 AM
Listers
Sep 30, 2015 07:45 AM
