Puff the Magic Dragon
Old Oct 13, 2014 | 03:51 PM
max224's Avatar
Default Puff the Magic Dragon
About half the time when I start my 2000 XK8 up, I get a large (and brief) cloud of blue oil smoke (car has 59,000 miles). The rest of the time I get nothing. My original prognosis was intake valve seals, but I tried letting it back down in a lower gear and then hit the gas - no smoke. I'm wondering if the crankcase ventilation system is somehow pressurizing the crankcase (intermittently) and forcing oil past the rings. I get some pretty nasty looks when the cloud initially appears, but it's done a lot to reduce the local mosquito population.
Anyone have this problem, or an idea what it might be?
Old Oct 13, 2014 | 07:29 PM
RJ237's Avatar
Intake seal wear causes a puff of smoke on startup. Ring wear results in a puff after backing down and hitting the gas.
Old Oct 13, 2014 | 07:34 PM
Gus's Avatar
Gus
Valve guide seals. If you are using 5w 30w oil move up to 10w 30w and see what takes place. I had this issue on my 93 xjs and it worked.
Old Oct 13, 2014 | 08:05 PM
test point's Avatar
Check the part load breather orifice. If plugged or restricted it may be sucking oil through the full load breather tube.
Old Oct 13, 2014 | 11:11 PM
Dr. D's Avatar
Here is the link if needed.
http://www.jagrepair.com/images/TSB/...20Breather.pdf
Old Oct 14, 2014 | 09:41 AM
max224's Avatar
Great! I'll give this a try. Thanks again; this forum has made owning this car so much more enjoyable (and saved me lots of $$$).
kurtomatic
Feb 12, 2024 06:58 AM
JWheeler
Nov 22, 2019 08:28 AM
damienedwards
May 2, 2016 04:51 AM
XFR_Gold
Sep 2, 2015 12:24 PM
XFR_Gold
UK & Eire
Sep 2, 2015 06:30 AM
