Radiator Fans Housing Crumbling
Old Sep 14, 2013 | 07:09 AM
Lannyl81's Avatar
Default Radiator Fans Housing Crumbling
'06 XK8 Convertable:
While searching for a possible cooling system leak I pulled on the radiator fan housing only to have a large piece of it come off in my hand. Tried a different spot along the top and same thing happened...small pieces just broke-off in my fingers.
Is this common? Are replacement radiator housings available? I have not found one yet.
Thanks guys.
Old Sep 14, 2013 | 07:53 AM
Jag#4's Avatar
Not sure if the radiator shroud is a common item for deterioration (don't think so), but brittle plastic is a common issue with the cars. There is a lot of heat in that engine bay. The heat and normal aging of plastic shows itself after a few years.
Look on eBay. There are several radiator fan shrouds listed.
Old Sep 14, 2013 | 10:57 AM
Lannyl81's Avatar
Will check ebay; thanks.
Anyone know what range of years will fit a 2006? I did not take the fans out in order to take a good look at it....did not want to break any more of the housing.
Sure be nice if this were made out of aluminum.
Old Sep 14, 2013 | 11:41 AM
JgaXkr's Avatar
I have a fan setup I will sell you. Let me know if you are interested.
Mac Allan
Jul 20, 2020 05:46 PM
Seth
Nov 1, 2015 12:17 PM
LnrB
Oct 13, 2015 12:45 AM
mrplow58
Sep 30, 2015 08:56 AM
