Radiator hose
Old Sep 15, 2020 | 03:58 AM
Mel Horman's Avatar
Default Radiator hose
Does anybody know what is the inside diameter of the radiator hose ? Thank You for your help. Mel
I have a 1997 XK8 convertible.
Old Sep 15, 2020 | 11:37 AM
michaelh's Avatar
Top hose is ~40mm ID at both ends.
Bottom hose is ~40mm ID at the top, ~42mm where it connects to the radiator. The clamp for that connection is slightly larger in diameter to accommodate.
I took these measurements from the old hoses, although they were not at end-of-life, just replaced with all the others to get to a baseline.
Old Sep 15, 2020 | 10:34 PM
Mel Horman's Avatar
Default Hose
Thank You Michaelh. I appreciate your help!
thebolenator
Jan 13, 2024 07:50 AM
Stamford
Mar 20, 2023 06:58 PM
cdma
Mar 26, 2020 08:07 AM
Mekka
Jan 4, 2020 05:34 PM
pratajag
May 22, 2013 08:18 AM
