radio
Old Sep 3, 2017 | 07:05 AM
rumm5's Avatar
Default radio
Hi all;
My radio powers up but no sound. I checked the fuses, radio lights turn on, antennae comes up, all the functions seem to work but no sound or static, nothing. The only clue I had is before the sound died, I got engine rpm related static I assumed was caused by a defective surge suppressor. I replaced same, but by this time, no sound. maybe something internal to the radio caused the static, or it's not related. Any ideas anyone? 98 xk8 conv.
Old Sep 3, 2017 | 10:30 AM
Johnken's Avatar
From what I've seen here this is often a loose connection to the amplifier in the trunk.
If you get a chance, tell us if you have premium sound system (tweeter pods [called "sails" from there shape] in doors forward of windows). I think all our 1998s were Harmon Kardon as opposed to later Alpine systems.
This will help troubleshoot. As I type I recall a gentleman from Europe who may have had same problem. It was a defective ground, look at antenna ground and search for his post/solution.
John
John
Old Sep 3, 2017 | 10:46 AM
DevonDavid's Avatar
As John says - more info required.
Is it "premium" or "poverty" specification (former has little door tweeters and an amplifier in the boot / trunk. Is it Alpine or Harmon-Karden. The latter (earlier) system has the LCD on the lower right and a sort-of multi-function joystick button for scanning, track changing etc. The Alpine head unit has the LCD in the centre.
Old Sep 4, 2017 | 08:24 AM
rumm5's Avatar
Default update
Hi all;
My bad, forgot pertinent fact. System is harmon kardon.
Old Sep 4, 2017 | 11:12 AM
DevonDavid's Avatar
Premium or Standard ? It matters as, with the standard kit, the speakers are connected directly to the head unit. On the premium system, the head unit send a low level audio signal to the amplifier in the boot (trunk) and the speakers are wired from there.
The amplifier shares the same power supply as the antennae, so it is probably getting power, but if it isn't getting any audio signal, then you would get the symptoms you describe.
Do you have the small tweeters on the doors ? That's an easy way to tell which system you have.
Old Sep 4, 2017 | 06:21 PM
rumm5's Avatar
Default tweeters
yes, harmon kardon w/ tweeters in doors
Old Sep 5, 2017 | 04:11 AM
DevonDavid's Avatar
.................. in which case, the first thing I would do is check fuse #9 (10A) in the boot (trunk). It's probably OK but easy to make sure. Then I would check the cables from the back of the head unit to the amplifier in the boot (trunk) at both ends. Both require a certain amount of dismantling - the trunk end is marginally easier so I would start there first. The audio cable is actually visible - it's a standard 8-pin (?) DIN plug/socket and should be at the side of the amplifier. Also check grounds (earths) - there are two black wires which ground the amplifier - presumably to a metal eyelet somewhere near the amplifier - if they have vibrated loose, it might cause your problem.
