Radio mystery
Old Sep 7, 2023 | 06:24 AM
markmywords's Avatar
Default Radio mystery
Hi all again!
Sorting things slowly on the XK8, but now the radio has come on on its own at night and killed the battery a few times..
Car is locked and radio turned off..!
I have tried a reset...
Any suggestions please shout..
Changed out milky dash..now go an airbag light on! doh..I did disconnect battery first..so will check the connections are firmly clipped on!
Any thoughts please dear souls
Old Sep 12, 2023 | 12:24 AM
Pistnbroke's Avatar
Well this does not fit the classic earth fault so I would pull the fuse and see if the problem goes away.
Personally I would just change the radio for a modern one with a 7 in pull out screen for about £70 see my posts
Old Nov 5, 2023 | 09:37 AM
Thank you, I will look into this idea, as muchg as I dislike DAB, it is good in cars!!!!
Old Nov 5, 2023 | 09:46 AM
However please can you give me link to your radiol ideas, as I have been searching (probably the wrong way!)
F-type-r-2022
Oct 18, 2022 03:50 AM
Rafael
May 1, 2021 11:43 PM
Blue Kittie
Jun 24, 2018 08:38 PM
93xjs6cyl
Apr 27, 2017 10:41 PM
tony bosco
Sep 1, 2015 02:06 PM
