Random beep-beep warning chime
Old Aug 28, 2020 | 03:56 PM
zray's Avatar
Default Random beep-beep warning chime
No alert messages, no high oil, coolant, or transmission temperatures. No nothing. Just this obnoxious beep beep. Car not in reverse, so not likely the back up warning. And no OBD-II fault codes.
seems like it happens when it’s hot outside, not extremely not, just in the 90’s (F), at least the a/c has always been in when the beeping occurs, iirc.
thankfully it doesn’t last very long , under 30 seconds, or I’d be 100% bonkers
any pointers on how to track this gremlin down ??
Z
Old Aug 30, 2020 | 07:06 PM
zray's Avatar
not expecting to stump the experts. Perhaps this anomaly really is unique
Z
Old Aug 30, 2020 | 08:12 PM
Gary VanRemortel's Avatar
Which sounder is it coming from, the steering column speaker or the rear console tweeter?
Old Aug 30, 2020 | 08:37 PM
zray's Avatar
the front speaker, and lasts about 10-15 seconds. .....also, Doors closed, engine running in park or neutral. By the time I can get the shifter into drive, it’s already over.
Z
Old Aug 30, 2020 | 08:49 PM
ccfulton's Avatar
Maybe you could post a recording of what it sounds like?
Old Aug 30, 2020 | 09:07 PM
zray's Avatar
I would have to fast on the draw, with my old man reflexes I have maybe a 50/50 chance of getting the beeping recorded, I’ll try though.
so far it’s happening maybe 0- 2 or 3 times a month, not very often for a daily driver car. So infrequently that I’m always startled when it comes on. I can’t recall if it happened last winter or when the weather was cooler. I need to start a beep(ing) journal.
at this point I’m thinking that the car in good faith is telling me something needs my utmost attention. But the information flow from the car’s many brains stops at just the loud beep beep beep beep, with no attendant visual warning from the dash and no OBD-II codes either.
at nearly 20 years old, perhaps the XKR’s brains are having a little dementia episode.
Z
KayuJag
XE ( X760 )
20
Jun 19, 2019 07:24 PM
Dell Gailey
May 14, 2019 07:50 PM
Dan_NL
Aug 13, 2018 11:09 PM
bkeats
E type ( XK-E )
Sep 2, 2015 09:38 AM
