random fault lights displayed
Old Apr 8, 2015 | 12:54 PM
thruxitup's Avatar
Default random fault lights displayed
Last week the xk8 displays DSC system failure display along side the ABS warning light. It did this when I first test drove the car at the dealer, it turned out the right hand front wheel sensor - this was replaced and all was well.
Thinking it may be the same problem reoccurring, I was puzzled to find on checking a couple of days ago in addition to DSC failure, the handbrake light on all the time, low brake fluid warning light(level ok), speedo not functioning and engine management light also on.
I put a new battery on as suggested in a search, checked and cleaned battery cable terminals and did the hard reset, all have no effect. I've now ordered an icarsoft i930 jaguar specific code reader, I'll report back when I start to use it.
(I should add that the car is out of warranty from the dealer and I try to do all the maintenance myself)
Paul
Old Apr 10, 2015 | 12:06 PM
thruxitup's Avatar
Default Strange fault codes...
Well, I hooked up the scanner and entered jaguar model and year but it kept coming up with communication failure with ecu on a completely random basis.
Eventually after much trying, I managed to get the following codes - U1041,
B1446, B1875, C1300 - does anybody know what these mean ?
I've cleaned the OBD11 port with contact cleaner to no effect, this scanner was bought with the intention of getting diagnostic help, I'm starting to think I've wasted £90...
Old Apr 10, 2015 | 12:38 PM
jamdmyers's Avatar
Try here and thank Gus
JagRepair.com - Jaguar Repair Information Resource
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
innzane
Sep 2, 2015 10:08 AM
