rattle at 3k to 4k rpm
Old Nov 6, 2009 | 02:43 PM
2000blackxkr's Avatar
Cool rattle at 3k to 4k rpm
i have a rattle that i cannot figure out were its coming from. it hits right about 3 gets really loud right about 3.5 then drops off as you get closer to 4.
any one have any good ideas what i should look for?
Old Nov 6, 2009 | 03:05 PM
test point's Avatar
Accessory belt tensioner bearing(?)
Old Nov 6, 2009 | 04:58 PM
Default rattle
OK, i will check that.
Is that a common thing?
Old Nov 6, 2009 | 05:35 PM
test point's Avatar
Jaguar redesigned the tensioner arm sometime around '00. Lots of reports of failures, some even have fallen off.
That was just a WAG by the way.
Old Nov 6, 2009 | 05:45 PM
Default rattle
i know that they were plastic at one point, i have the updated metal tensioner components.
Old Nov 8, 2009 | 09:54 AM
chazaroo's Avatar
the problem wasn't accessory belt tensioners. It was timing belt tensioners. The uppers tended to give out which would destroy the engine. I would suggest that you have the tensioners checked before driving the car again. In fact might be a good idea to have them checked before even starting the car again.
Old Nov 8, 2009 | 08:05 PM
Default rattle
chazaroo,
I have already replaced the primary and the secondary tensioners. I replaced the chains and guides as well. But i will pop off a cover later and take a look and see if any thing is amiss.
BrentGardner
29
Dec 16, 2024 12:13 AM
Unhingd
Jan 20, 2016 08:43 PM
hunterpedigo
Oct 29, 2015 05:31 PM
inactualis
Oct 2, 2015 11:13 AM
dalippy
Aug 21, 2015 03:18 AM
