Rear fender emblems
Old Nov 26, 2015 | 12:52 PM
max224's Avatar
Default Rear fender emblems
I just bought the "Jaguar" and "XK8" emblems that go on either rear fender. They are adhesive-backed, and I'm assuming that the ones that are there already are attached in a similar manner. Any suggestions on removing them without damaging the paint? I was thinking that the judicious use of a heat gun would probably work, but am open any other ideas or suggestions.
Thanks in advance.
Max
Old Nov 26, 2015 | 03:12 PM
StuG's Avatar
A heat gun or hair dryer and then fishing line used in a sawing action usually does it without any paint damage. Any leftover adhesive can be easily removed using WD-40. Clean the area afterwards and wipe with an alcohol pad before applying the new emblems.
