rear window regulator mystery
Old Jul 11, 2016 | 11:04 AM
dr.fixit's Avatar
Default rear window regulator mystery
Yesterday, I replaced my right hand rear 1/4 window regulator. The glass was in the up position. After reconnecting the ground to the battery the window automatically went down. I suspect that was the right thing for it to do since the other window was down, as was the top. I went to close the top and here is what happened.. The top went up, but the latch did not close, therefor the windows did not go up. I opened the valve on the hydraulic pump and manually locked the latch using the allen key in the slot above the mirror. Sounds like a limit switch is not working. I also noticed 2 wires near the right hand hydraulic cylinder, very small gage wire maybe 22 or 24 ga. with a rubber connector on the end . One is by the bottom end of the cylinder, the other near the top, inside the rubber connector, there looks to be a brass screw head, with the screw part sheared off. could these be the limit switches?? I attached a pic. HELP !!!!
Old Jul 11, 2016 | 12:21 PM
dr.fixit's Avatar
I should also add that the right hand hydraulic ram moves up and down. I don't think that is supposed to happen. Am I correct?
Old Jul 14, 2016 | 08:55 PM
dennysjag's Avatar
Default switch
Those switches are part of the operation of the latch operation. is it broken off? or unpluged?
Old Jul 15, 2016 | 01:08 PM
dr.fixit's Avatar
Both the open and close limit switches were broken, so the entire roof closing sequence was out of sync. With the help of Dave ( dsnyder586) I replaced the right hand cylinder and everything is back in working order. Once again, thanks Dave.
BobRoy
49
Sep 18, 2016 10:48 AM
rsq911
Apr 1, 2016 11:23 AM
tibam13
Mar 26, 2016 05:58 PM
Detailing / Car care
Jan 18, 2007 11:07 PM
Aug 1, 2006 04:09 AM
