Reference: Front Sway Bar Bracket bolt size
Old Jul 7, 2019 | 08:29 AM
Johnken's Avatar
Default Reference: Front Sway Bar Bracket bolt size
Front sway bar bracket uses two: M8 1.25 16mm bolts. They are inexpensive ($3.50 quantity 5) and readily available as grade 8 bolts.
Given access restrictions why put in a bolt below grade 8.
The factory bolts are same size of course, but they have a 10mm head. The M8 for sale around here are all m13 hex head size.
You will need a 24 inch extension. How did I get the bolt to stay in place while I threaded it down to the bracket? I used a dab of Goop brand adhesive. It's a flexible high viscosity adhesive that'll hold things together under light stress (so if I took too long I could easily pull the wrench off). See photo.
JFT10816EP is the Jaguar part#. It was $6 + 5day wait from them. Like I said this is available in your local auto parts store.
Johnken
Jun 14, 2019 06:51 PM
brgjag
Oct 23, 2015 07:31 AM
jimlombardi
Nov 3, 2014 07:35 PM
04xtype04
May 4, 2014 09:27 PM
Thesicilianpr
Nov 10, 2013 09:20 AM
