remote
Old Sep 23, 2013 | 10:42 AM
jjf's Avatar
jjf
Default remote
My 98 XK8 only came with 1 key so bought a remote on Ebay (LJA2610AA). Got it programmed, but when I lock doors/set the alarm, the passenger door handle cycles a few times and the alarm goes off. Anybody figure out a cure for this? I'm about to give up and return the remote.
Old Sep 23, 2013 | 10:45 AM
WhiteXKR's Avatar
That is not a problem with your remote. It sounds like it is working fine.
You likely have a bad microswitch in the door latch mechanism, probably on the driver's side.
Old Sep 23, 2013 | 11:37 AM
jjf's Avatar
jjf
ok. I didn't think it was in the passenger side door because I recently replaced that whole door, and it cycled before without a remote.
I think I viewed the latch change-out on a 'Sam video'.
Are the micro-switches available separately, or must buy the whole latch assembly?
Old Sep 23, 2013 | 01:41 PM
....... Are the micro-switches available separately, or must buy the whole latch assembly?
They are available separately.
Description: Microswitch - door latch
Part Number: C2N 1908
Old Sep 23, 2013 | 03:36 PM
WhiteXKR's Avatar
Do check fuse #15 on both the passenger and driver door fuseboxes before you buy any parts. A blown fuse also has the potential to cause this problem.
Old Sep 23, 2013 | 03:42 PM
jjf's Avatar
jjf
I checked both those fuses and they were ok.
If the #C2N 1908 microswitch is bad, would that give me a "door ajar" message" also? I 'm not getting any door ajar message, and the windows work as they are supposed to (a new battery solved window issues).
Old Sep 23, 2013 | 03:45 PM
WhiteXKR's Avatar
I actually think it is one of the other two door latch assy microswitches that causes the cycling issue.
Old Sep 24, 2013 | 07:28 AM
jjf's Avatar
jjf
yesterday, I took the door latch off, cleaned & lubed it, and reassembled... Now I'm getting a "door ajar" message that I didn't have before. Is there a way to test the micro-switches? One of them looks easy to replace, not sure about the others.
Old Sep 24, 2013 | 09:34 AM
WhiteXKR's Avatar
Switches can be tested with a multimeter on resistance setting.
Swagguar
Sep 30, 2015 01:34 PM
zdrapec
Sep 25, 2015 05:49 AM
kevinl
Sep 24, 2015 08:25 PM
kabs3012
Sep 12, 2015 10:40 AM
