Remote Trunk Boot Switch
Old Sep 15, 2011 | 10:43 AM
platinummaker's Avatar
Pophen I am trying to understand how the system works and obviously I don't, but I agree to me the symptoms are of a valet switch that does not disengage and I'm still troubleshooting.
Thanks for your input.
Frog I had the local body shop that does the work for the Jaguar dealership tint/paint and clearcoat the tail and brake lamps. While some I'm sure would not like the look, I could'nt be happier with the way it has turned out. It has not diminished the light level significantly when lights or brakelights are applied but in my opinion has cleaned up the rear of the car and added a stealth factor. The car is black and although the flash on the camera provided additional directed light on the lights, they appear to blend in the rest of the body. Thanks
Old Oct 6, 2011 | 07:37 AM
wlbusmcr's Avatar
Default XK8 Trunk Lights
They have a mind of their own and come on when they want and go off when they want. Checked for a plunger switch but could not find one .
Thoughts?
Suggestions?
Thanks,
Bill
Old Oct 6, 2011 | 09:14 AM
Paul Pavlik's Avatar
Thoughts?
Suggestions?
Thanks,
Bill
The switch is located in the Latch Assembly in the base of the Trunk. To service it, you must remove the plastic cover in the Rear base of the Trunk.
Old Oct 6, 2011 | 12:24 PM
H20boy's Avatar
found my valet button likes to stay 'depressed' in its hole...any chance there?
H20boy's Avatar
don't forget, once the valet button is used, you must 'unlock' the car using the keyfob to deactivate it.
dsnyder586
Dec 29, 2024 07:39 PM
mbergen
Oct 23, 2019 10:26 PM
kabs3012
Sep 12, 2015 10:40 AM
jagent
Sep 12, 2015 09:10 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
