Removal of chrome plinh under shifter
Old Jun 16, 2014 | 09:54 PM
03xkrconvertible's Avatar
Default Removal of chrome plinh under shifter
Hi guys,
I'm trying to replace a broken Jgate plastic top with a good assembly from Elite in LA but haven't figured out what tool is needed to remove the cone shaped plinth under the shift knob (which is now off.) I can see two holes 90 deg apart but can't make out what it is. I tried a small metric hex wrench but couldn't get a bite.
Also trying to track down the location of where the Jgate connector plugs in. Do I have to remove the radio or something else?
Old Jun 19, 2014 | 06:51 AM
larueb's Avatar
When I replaced mine it was straight forward. The set wrench or hex wrench should work easily. The connectors for the cruise and shift mode are easy to get to, no need to touch the radio.
LaRue
Old Jun 23, 2014 | 08:27 AM
Larue,
Thanks got it! I was concerned I might mess something up when I saw the holes which looked like set screws but it spun right off.
Old Jun 23, 2014 | 09:26 AM
larueb's Avatar
Glad it worked out for you.
danke
Mar 3, 2016 10:57 AM
DannyRobertHoward
Sep 30, 2015 01:51 PM
doctordeuce
Sep 12, 2015 08:30 AM
sadepol01
Sep 11, 2015 05:26 AM
1964Daimler
Sep 9, 2015 11:28 AM
