Removal of Headlamp Bracket Lower Torx Bolt
Old Oct 29, 2023 | 01:57 AM
RayR's Avatar
Default Removal of Headlamp Bracket Lower Torx Bolt
I recently replaced a broken headlamp washer jet on my 2005 XKR. In doing so, I also encountered the dreaded M40 Torx bolt that connects the underside of the headlamp assembly to a metal bracket. I squirted it with penetrating oil, let it sit for a while, and then used a ratchet to extract the bolt -- or so I thought. What really happened is the bolt was frozen to a brass fitting that was molded into the plastic of the headlamp case. So, the plastic broke and the bolt with its brass fitting came out as a single unit. (I was later able to separate them.) Any recommendations on what to do next? Can I just ignore the lack of a lower bolt? Can this be repaired? I sure don't want to pay $2K for another headlamp assembly.
Old Oct 29, 2023 | 02:20 AM
giandanielxk8's Avatar
JB-Weld
Old Oct 29, 2023 | 02:37 AM
Pistnbroke's Avatar
Leave it out ..the two other bolts are enough and you can get it out in future without going under the wheel arch.
Ant Buck
Oct 7, 2023 07:31 AM
Jag1968
May 27, 2021 10:39 AM
stevepaa
Jun 19, 2020 10:54 AM
Lannyl81
Oct 25, 2016 07:17 AM
jahummer
Feb 24, 2015 10:39 PM
