Remove/Install Crank Pulley Procedure
Old May 18, 2015 | 12:45 PM
Majik Lasers's Avatar
Default Remove/Install Crank Pulley Procedure
Does anyone have a documented procedure that I can use as a guide for changing my crank pulley? I received my upper and lower pulleys from Eurotoys. I started the upper 2.5 psi pulley yesterday and will be finishing up within the next couple hours (currently about 90% filed down). I'd like to see what others have done to remove and install the lower pulley without a locking tool. Is it necessary to replace anything else when performing the lower pulley procedure?
This is the type of puller that I have...which I've used on my Thunderbird 4.6 in the past without issue. I assume this will work for the Jag as well...
Also, my torque wrench isn't capable of 285 ft-lb. I suppose its necessary to buy/rent one?
Attached Thumbnails Remove/Install Crank Pulley Procedure-otc-7403.jpg
Old May 18, 2015 | 01:14 PM
motorcarman's Avatar
Quick and dirty!!!!!!!!!!!!!
Works every time.
bob gauff
Old May 18, 2015 | 01:35 PM
Chain wrench...nice! Thanks! Now to the challenge is to find one this afternoon...
I was going to use the starter method to initally crack the bolt loose; unless you have another suggestion.
Old May 18, 2015 | 01:37 PM
What size chain wrench is that btw?
Old May 18, 2015 | 09:12 PM
It is the Harbor Freight 24" I bought about 15 years ago.
My buddy has a Blue Point but it costs about twice as much.
bob gauff
Old May 18, 2015 | 09:15 PM
Make SURE you wrap a section of drive belt around the pulley!!!!!!!!!!!!!!!!!
bob gauff
Old May 20, 2015 | 07:28 AM
Got it. Thanks, Bob.
Corycarlo
Oct 3, 2015 09:33 PM
inactualis
Oct 2, 2015 11:13 AM
Doug S
Sep 30, 2015 02:03 AM
ziondio
Sep 29, 2015 01:58 PM
