Replace ac hose
Old Aug 22, 2017 | 12:50 PM
twmotox's Avatar
Default Replace ac hose
I have a 99 XK8 and I wanted to see if anyone has replaced the ac hose from the evaporator to the compressor and if so how?
Old Aug 22, 2017 | 02:16 PM
motorcarman's Avatar
There is a TSB for this (X308 sedan but nearly identical problem). The replacement hose(s) is/are 2 piece. A tubing cutter or small cut-off wheel is used to sever the original and then the replacement hoses are installed.
I had to do this a few months ago on a customer 1999 XK8.
I chose to displace the compressor forward to get the one hose in place but the recommended procedure is to remove the left cataverter from the flange.
I also dropped the steering rack a little for access.
See the TSB for info.
bob
Old Aug 23, 2017 | 08:16 PM
twmotox's Avatar
Thanks for the reply. That is very helpful
