Replace Alpine navigation with Denso?
Old Jun 11, 2009 | 12:29 AM
glenn's Avatar
Default Replace Alpine navigation with Denso?
Wondering if anyone has tried this before. Dash layout and controls look the same. Thought this might be a solution to getting newer maps for those of use with the old Alpine system. Plug in replacement or major changes to cabling etc? Thanks.
Old Jun 11, 2009 | 12:40 AM
H20boy's Avatar
doubt it would since all components (deck, navigation, cd changer, and amplifiers) are alpine, they have the same BUS cummunications, and when one stops talking the same language the whole system doesn't work. nobody has been able to replace a CD changer, let alone a nav system and keep the stock system operating.
Old Jun 24, 2009 | 10:52 PM
glenn's Avatar
Right, I see your point is well taken. Oh well...stuck in time!
Old Jun 25, 2009 | 01:31 PM
H20boy's Avatar
If you search in the audio/visual area, I ended up using my stock screen for an aftermarket Garmin 'blackbox' nav unit. Works pretty cool, just have to do a little RGB video splicing, install a NAVTV switch box (if you want to keep the clock, otherwise, none needed), add a video toggle switch below your dash (same reason above), and tap into the amplifier leads for voice directions along with the tele-mute line of the Alpine deck. Everything is remote ran on the Garmin and you're all of a sudden using 2009 maps!
I'd estimate under $1000 damage for a system upgrade by your local shop.
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
KarimPA
Sep 12, 2015 08:15 AM
tberg
Sep 7, 2015 07:32 AM
KarimPA
Sep 3, 2015 07:32 PM
