replacing outer door handles- just the handle
Old Mar 24, 2014 | 07:06 PM
TreVoRTasmin's Avatar
Default replacing outer door handles- just the handle
I lent my car to a friend back in Nov and got it back wit a broken outer door handle. My car was repainted so I know matching the paint will be tough so I'm just going to try to replace the chrome handle only. Question is since I had to drill out the "pin" on the donor I now need a replacement. Any ideas on what to use. The pin is roughly 4 inches long and 3/16" thick. I would need to be able to put two hads on it and I doubt I can weld them on as the pot metal and nylon washers won't take the heat well.
Old Mar 25, 2014 | 08:17 PM
Bought a 6" #10 stainless steel threaded rod and some ss nylon nuts. Also got some red thread locker just to be sure the nuts stay in place for the long haul. Will respond if it all works out.
Old Feb 5, 2015 | 04:38 AM
Padrino's Avatar
Default About to do the same handle replacement
Found your short posting as I've got the same broken handle issue and I'm about to replace it. I've got the same repaint issue and don't want to remove the handle surround for fear of breaking the paint somewhere.
I have a whole new (used) door handle assembly. Any pointers you can provide before I attempt this? I know, disconnect the battery!
JarodL
Mar 7, 2024 01:39 AM
Sprayall
May 30, 2021 08:13 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
Sprayall
Sep 3, 2015 07:49 PM
frankc
Sep 1, 2015 04:41 AM
