Replacing steering wheel - help disconnecting airbags please
Old Dec 16, 2012 | 05:15 PM
pomosv's Avatar
Default Replacing steering wheel - help disconnecting airbags please
I will be getting my steering wheel rewrapped, and I picked up a cheap jag replacement wheel from the wrecker I'd like to put on in the meantime - can someone point me to how I properly disconnect the airbag and remove it from the wheel? (I'm ok with the mechanical side, just the electrical side procedure - don't want it blowing up in my face!). Thank you.
Old Dec 16, 2012 | 05:27 PM
This is the JTIS procedure:
1. disconnect battery positive lead
2. allow at least one minute for the backup power supply to dissipate
(My preference is to do a Hard Reset by touching the disconnected positive lead to the earth lead for approx 20 seconds)
Remove air bag module securing bolts as follows (this view is from behind the steering wheel):
Replacing steering wheel - help disconnecting airbags please-steering-bolts.jpg
3. Turn steering wheel 90 degrees to the left to provide access to module LH securing bolt
4. Fully slacken captive securing bolt and remove it
5. Turn steering wheel 90 degrees to the right to provide access to module RH securing bolt.
6. Fully slacken captive securing bolt and remove it
7. Remove air bag module from steering wheel
8. Carefully withdraw airbag module from steering wheel and position for access
9. Disconnect air bag module harness multiplug and remove air bag module from vehicle
With the battery disconnected, it's extremely difficult to turn the steering! The bolts can be slackened before (1) in the procedure.
Old Dec 16, 2012 | 05:31 PM
pomosv's Avatar
Excellent, thank you!
Got the steering wheel out. Any recommendations on where to send it for an oem-like leather rewrap?
Old Dec 23, 2012 | 05:00 PM
Gunmucker's Avatar
I am looking into solutions to repair the worn leather on the steering wheel on my S-type. I found this, if it helps. It looks like they can do what you are after.
B&I® Steering Wheel - Fully Customizable - 2002 Jaguar XK-Type Steering Wheel - B&I BI-TRTAWX-XX-XX
tonimccloud
19
Jan 18, 2020 01:56 PM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
SkinnyLard
Aug 30, 2015 07:26 PM
SkinnyLard
Aug 29, 2015 04:24 PM
J-Rock
Aug 25, 2015 08:33 PM
