Replacing XK8 Headliner
Old Jul 21, 2014 | 09:23 AM
chambersmd's Avatar
Smile Replacing XK8 Headliner
Recently had to have the headliner in my coupe replaced because it was sagging and the friction was enlarging my bald spot In the process of getting estimates, I learned the following that I thought some of you might benefit from:
1. One shop said that they would have to remove the windshield (OMG!) to replace the headliner. The good news is that I found another shop that was able to do the job without removing the windshield.
2. The OEM fabric for the XK8 coupe is not the same as that used in most cars. So if authenticity matters to you, make sure that the shop will be using the right stuff. (But it is expensive - $50/yard.)
Old Jul 21, 2014 | 09:45 AM
Alan-the-ifa's Avatar
Default replaced mine 18 months ago....going again !!!
Hi I replaced mine myself. got a new pre covered abs liner with genuine material attached via an upholstery company on ebay. Main issue is squeezing it in the passenger door aperture with seats and centre console causing most issues. When I do it again I will be removing those first!!. Anyway main point is the new one is sagging again already. I contacted the vendor who insists it must have been damaged on fitting, if I would like to remove it and return for inspection they might consider recovering it if its the glue at fault!!!!!
Where do I get another cardboard box that big and what's it going to cost to return, no I don't think so.
Considering two parallel cuts of headlining material one third across the roof front to back, re gluing with contact adhesive and applying a contrasting ribbon of material an inch or so wide to hide the seam. I am hoping this would relive the tension in the material enough to keep it stuck.
Anyone any other suggestions?
Old Jul 21, 2014 | 09:50 AM
mrobinson's Avatar
Default Rattling dashboard
Sorry, posted in the wrong place. Deleting my post
Old Jul 22, 2014 | 07:34 AM
guzzi svt's Avatar
Drive to KC, Noth Kansas City Auto Trim, $170. I think they remove the at least the drivers seat, maybe both.
Don't let anyone remove the windshield. That's a two month long other story!
Good luck!
Old Jul 22, 2014 | 12:42 PM
Jochem00's Avatar
50 usd a yard expensive! For the right stuff!
You will only need about 1,5
So not expensive at all.
Whole job can be done in 3 hours including relining the liner. Very easy
toronadomike
Jan 22, 2026 10:13 PM
kelliott
May 31, 2022 05:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
David Thompson
Sep 3, 2015 07:48 PM
KarimPA
Sep 3, 2015 07:32 PM
