restricted performance
Old Sep 30, 2017 | 01:40 PM
magnum454's Avatar
Default restricted performance
Gentlemen, when I read the codes I got "354 coil primary/secondary. The number 4 is on the side with the air intake. It was suggested to switch 4 with 3 and see if the code changes to "353". Because that's a lot of work, can I safely assume that it's the coil on #4?
Old Sep 30, 2017 | 02:09 PM
joesoap's Avatar
yes or the plug or connector to coil, that's why if you swap coil it eliminates one of them.
Old Sep 30, 2017 | 07:59 PM
RJ237's Avatar
If that's a lot of work I hope you have no other problems. Be advised that the location of #4 depends on whether you have a 4.0 or 4.2 engine.
Old Oct 1, 2017 | 06:13 AM
Originally Posted by magnum454
.... can I safely assume that it's the coil on #4?
It's a Jaguar - you can't 'safely assume' ANYTHING.
