Restricted performance message 2001 XK8
Old Mar 13, 2015 | 06:34 PM
noterman's Avatar
Default Restricted performance message 2001 XK8
After an engine swap I had a check engine light and Restricted Performance message. I had numerous fault codes which I cleared, but I still have the check engine light on and Restricted Performance message. I checked and I do not have any new fault codes. I do have a battery not charging message with red and amber warning lights. I also have the ABS light on.
I have 13 volts on the amp gauge with the engine running.
Thanks for your help.
Old Mar 13, 2015 | 08:41 PM
ccfulton's Avatar
You should check the voltage with a proper volt meter while the engine is running but 13 is not enough. You should see at least 14v with a good alternator, usually a bit more than that.
Old Mar 13, 2015 | 08:50 PM
noterman's Avatar
I have 14.3 volts with the engine running at the battery, for some reason the gauge in the car reads 13 volts. Thanks
Old Mar 13, 2015 | 08:59 PM
WhiteXKR's Avatar
See if fuse #2 in the left side engine compartment fusebox might have blown.
If not, check the white-blue and the yellow wires at the alternator which might have been detached or damaged during the engine swap.
toronadomike
Jan 22, 2026 10:13 PM
D.K
Dec 10, 2023 02:05 AM
PMKimpton
Aug 3, 2019 08:22 PM
Kmw
Sep 8, 2015 04:52 PM
XFR_Gold
Sep 2, 2015 12:24 PM
