Restricted Performance On and Off
Old Aug 2, 2017 | 10:29 AM
robert53's Avatar
Originally Posted by graham11
Looking from the front of the car B coil will be first on the right
G coil H coil
E coil F coil
C coil D coil
A coil B coil
​​​​​​​ FRONT
I'm have a codes:
P0302 Cylinder 2 misfire
p1313 Misfire Rate Catalyst Damage Fault Bank 1
P0352 Ignition Coil B Primary/Secondary
P1111 System Pass
If I'm reading this and the engine cylinder diagram correct, I need to replace Coil B, which is the second cylinder in Bank 1 facing the engine. Does that make sense?
THanks
Old Sep 2, 2017 | 04:42 AM
olca's Avatar
My XK8 with restricted performance message first and then no-start problem is repaired now. It was one of the ignition coils that had been shorted as bad as getting overheated and the plastic had melted. It blew the fuse for the ignition coils. Replacing the coil and a new fuse fixed it.
Old Aug 8, 2020 | 07:54 PM
SHEJAGinNZ's Avatar
Thanks to all for the info on thos post, exactly the same thing just happened to my XK8, shorted and seriously melted coil pack causing blown coil fuse
