RHS EXhaust cam moving after cam locks removed.
Old Apr 11, 2020 | 09:51 AM
O&DR's Avatar
Default RHS EXhaust cam moving after cam locks removed.
Trying to change the timing mechanism (guides, chains, tensioners etc).
Followed the cam sprocket tightening procedure.
LHS chains are still tight and looks good after removing the cam lock.
However, when I release the cam lock from the RHS the cam exhaust (small sprocket) moves clockwise.
This seems to be because the cam is under pressure from the valve springs.
This causes both chains on the RHS to become loose on the drive side.
Retried to sequence several times with same result.
Is this normal and nothing to worry about ?
Old Apr 12, 2020 | 03:16 PM
O&DR's Avatar
Seems to be normal.
Refitted the crankshaft pulley, rotated the crankshaft 180 degrees and found the issue had move to opposite bank.
Must be the timing as the cams start to act on their springs.
Old Apr 12, 2020 | 03:21 PM
NBCat's Avatar
Are the crankshaft sprockets in the correct positions?
Are the primary timing chain tensioners correctly positioned to maintain tension on the chains?
Are the VVT units on the inlet cams fully retarded?
Old Apr 12, 2020 | 04:37 PM
O&DR's Avatar
Sprockets ok, tensioners ok, VVT units fully retarded.
Moved the crankshaft over 360 couple of time’s and everything aligned correctly each time.
Just the action of the valve springs on the exhaust cams pushing them round slightly when static.
Dickie_L_J_O
Sep 13, 2015 07:44 AM
anthonyisd3ad
Nov 23, 2011 03:59 PM
EZDriver
Mar 7, 2011 08:48 AM
Rev
Mar 16, 2010 12:22 PM
ronmexico
Jul 24, 2009 01:15 AM
