Roof switch (console)
Old Sep 19, 2009 | 10:27 PM
kntjafo's Avatar
Default Roof switch (console)
Good evening all,
This is only my second post, though I read the forum every day. Much great info here. Now I need help with how to remove the roof control switch from the center console. The top goes down with the switch, but will not come up. Works fine using the key. I searched the archives and did not find anything related to that particular switch. Thanks for any help. By the way, I will be retiring in December and will be leaving California and heading back to the mountains of North Carolina, over looking the Blue Ridge Parkway!
Thanks,
Butch
Old Sep 20, 2009 | 01:09 AM
H20boy's Avatar
You've got to get under your gear shift bezel and that wood trim piece. First step, take a stiff credit card, and imagine your bezel as a clock. At 2:00, 4:00, 8:00 and 10:00 use your card to push in, directly left and right into the bezel. There are little tabs that need to be pushed in towards the gearshift. One at a time, and slightly lift up. Be ready to unplug the cruise and/or sport button as you lift it up about 6". Second, you see these little metal bands that hold the wood veneer in place. Remove the two screws per side and the wood veneer should come up real easy. Roof switch is snugly in this piece. I'd take it up to the dealer, get a new switch, and let them pop out the old and new one out and back in. They'll do it for free if you buy the switch from the parts dept. Otherwise, go at it yourself, try to see if the switch is bad...worse case you bust the switch, or worse yet...the wood.
Old Sep 20, 2009 | 04:41 PM
kntjafo's Avatar
h20boy,
Thanks for the info. i was hoping there was someway to remove the black plastic tray, a coin holder I think. After 30+ years of owning Jaguars i should know nothing is easy Thanks again.
Butch
Old Sep 21, 2009 | 09:47 AM
H20boy's Avatar
you bet butch, good luck w/her!
280zx-turbo
Feb 11, 2020 02:20 AM
jzanone
Dec 30, 2015 05:50 PM
dstary
Sep 19, 2015 09:47 AM
eurotire
Sep 18, 2015 07:27 AM
280zx-turbo
Sep 10, 2015 06:29 AM
