Rough Starts
Old Nov 26, 2022 | 08:17 AM
Flash-1973's Avatar
Default Rough Starts
Greetings Cat lovers, My 01 XK8 with 67k mi starts rough, generally after making a few errand stops. I thought it may be the Throttle Body, but now leaning towards fuel pump. Upon initially turning over I hear a rattling or kind of thumping coming from the fuel tank area.
What say you?
Thank You,
Bill
Old Nov 26, 2022 | 08:46 AM
Pistnbroke's Avatar
You need to tale out the rear parcel shelf ..remove speaker blank and then cut to open up the hole for access ..7mm and long extension ..run the fuel down.
Old Nov 26, 2022 | 10:34 AM
Flash-1973's Avatar
Hi Pistnbroke, So you concur it’s the fuel pump?
Thank You
Old Nov 26, 2022 | 02:28 PM
Pistnbroke's Avatar
No I just tell you how to do it a pump in the UK is only $18,,,you should check the Schrader valve for a squirt
Dallyb
Oct 2, 2021 07:12 PM
Alex.S
Jul 20, 2017 02:26 AM
randyb
Dec 23, 2011 12:15 PM
burmaz
Nov 13, 2011 05:29 PM
Two jags
Nov 5, 2010 10:11 PM
