RR all power steering lines
Old Jun 25, 2019 | 10:55 AM
ken qv's Avatar
Default RR all power steering lines
High pressure line was leaking so time to do them all.. anyone here have ALL their power steering lines replaced? Wondering approx cost...? Other things to consider or look out for?
thank you gentlemen
Old Jun 25, 2019 | 12:27 PM
fmertz's Avatar
Some have done home-made repairs instead of the expensive Jaguar lines. Generic lines and worm-gear clamps type of stuff. Might be one of those situations were these expensive quick-connect lines really help Jaguar at assembly time, but are much less valuable to us down the line.
FWIW, keep in mind this system has a cooler in front of the radiator, so there is more plumbing than you would think initially, i.e. $$. I would do the high pressure line (possibly with a factory part) and then check again later if it was me.
Best of luck, keep us posted.
Old Jun 25, 2019 | 12:44 PM
DavidYau's Avatar
Default Original OEM parts NLA
Not sure what model you have, but I found the original OEM parts for my GEN1 1999 XK8 weren’t available. Cost wasn’t the issue - f£&king NLA. Leaking at the rubber steel crimps on the line was my problem. Later GEN parts followed completely different route through the engine bay and only this forum showed me how/where.
Managed to get line from PS pump to rack pipe in new route but not the other. My coolant radiator rail was ok, thank goodness, as changing that too would have meant other re-piping route.
I certainly see why people DIY the pipes.
Good luck
Old Jun 27, 2019 | 01:45 AM
DavidYau's Avatar
Default Power Steering Line repairs
Just going through "old paper work" and found these bits that might help you.
Link to Thread I used
https://www.jaguarforums.com/forum/x...g-hose-108685/
With pic of receipt I had from Supplier
mirisisa
Dec 18, 2019 09:13 AM
muttony
Jul 29, 2019 11:14 AM
JeffR1
Jun 19, 2019 05:46 PM
MarcB
Jan 16, 2012 10:29 AM
GoobeGustafson
Dec 3, 2011 10:52 AM
