S/C single sided belt (re)conversion
Old Oct 22, 2012 | 04:31 PM
ccfulton's Avatar
Default S/C single sided belt (re)conversion
My car has the double sided belt conversion (just the S/C) but I'd like some more options for belt length, for pulleys and such. From inspection, it looks like the only pulley that runs on the outside of the belt is the idler, and the others (S/C, crank and tensioner) all run on the inside that would have been ribbed anyway.
So, two questions:
1) Is the idler the only one that I need to change?
2) Anyone know of a source for a smooth pulley? I checked Gaudin, and they have the smooth version listed as obsolete and only have the double ribbed model available.
Thanks in advance.
Old Oct 22, 2012 | 06:25 PM
plums's Avatar
Almost all of the aftermarket idlers are smooth. Look over at rockauto to get a picture and part number. About $20, so much cheaper than anything Jaguar is going to sell you anyways.
Old Oct 22, 2012 | 07:38 PM
ccfulton's Avatar
Rock auto doesn't list one explicitly for the S/C idler but is it the same as the accessory idler? The parts catalog says it's a different number but that doesn't necessarily mean that it's actually different.
Old Oct 22, 2012 | 08:23 PM
plums's Avatar
Try looking in a different section of their catalog as it can fall under air or fuel systems.
Or, check the online manufacturer application catalog which gives a full description and dimensions.
Old Oct 22, 2012 | 09:34 PM
H20boy's Avatar
If you would have mentioned this over the weekend, you could have had my old idler pulley from my superv8, i just changed the whole assembly - belt, idler pulley, tensioner, and idler pulley bracket to fix the squeaky belt when cold syndrome. It was put in the trash on the curb this morning...nothing wrong with any of the old parts either.
Old Oct 22, 2012 | 10:53 PM
ccfulton's Avatar
Well crud, a day late and a dollar short...
Forcedair1
Feb 19, 2020 01:51 PM
ccfulton
Sep 20, 2015 05:15 PM
Nasayr
Sep 9, 2015 06:20 AM
Jay48
Sep 7, 2015 09:30 PM
sklimii
Sep 5, 2015 06:04 AM
